Hi!
I need a step-by-step tutorial on using FFMPEGX to convert RM to MP4.
I have downloaded & installed the latest version (0.0.9w)
and have downloaded & installed the various suggested libraries.
When I try to covert, I get the following Applescript Error:
Does anyone know what this means, or what I might be doing wrong?Can't get text item 2 of "Binary file (standard input) matches". (-1728)
All & any help is most welcome
TIA
Results 1 to 11 of 11
Possibly you installed ffmpegX in a subfolder of /Applications or your disk name contains special characters?
Hi
FFMPEGx is installed in the Applications foilder, not a sub-folder.
My disc name contains no special characters (Macintosh HD).
The binaries, mpeg2enc and other libraries have ben installed in /Library/Application Support/ffmpegx.
All I want from this program is to be able to occasionally convert a RealMedia video to a Quicktime compatible video.
Any other suggestions?
TIA
Sorry, not realy as I convert to AVI to then edit in QuickTimePro. For sure, next time you succed, create a presset right away.
Good Luck
What settings do you use in ffmpegx to convert rm to avi.
I'd be happy to go that path & then finish it in QT
OK I'll try to be clear as possible.
in the summary tab, you drop your .rm file (not a .ram, if so, change the suffix before the drop).
In the target format , choose AVI DivX.
In video tab, Video Codec is MPEG4[.AVI] (mencoder)
Video bitrate is 516 / parameters 640X480 / autosize 4:3 /
frame rate NTSC (29.97)
audio is .MP3 at 128 kbit/s / 48000 Hz / CBR
No filters used in my setup and the rest is preset
Good luck it has worked fine and I convert a lot of real Videos with this setup.
Many thanks!
I have finally got the conversion working
Only one more thing, the audio seems to be slightly out of sync with the video on the converted file. Just enough, on a music video to make it look like miming.
It wasn't on the original rm file.
Any thoughts?
Once again, thanks for the input.
Could not be very usefull on audio more detailled specs. You might find some stufff about Real audio codecs. This corp. works mostly on streaming media. Maybe changing data rate could help to synchro. Scan and read about it. You will find awnsers as I did for the video convertion. Good luck
How can i convert videos (Mp4) to frames
By aplink in forum Video ConversionReplies: 11Last Post: 18th Feb 2012, 17:56 -
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 7Last Post: 26th Jan 2011, 22:25 -
Help! Some MP4 videos can't be read
By adf in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 00:17 -
Any possible help please, with understanding my MP4 videos
By JohnBarnshaw in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 15:40 -
problem coverting videos for Sony NWZS615FB player
By dona in forum Video ConversionReplies: 1Last Post: 27th Dec 2007, 10:13
