Hi guys,
I figured out part of the toast .avi problem. When I use the Divx FFmepg the new file works perfectly in VLC. VLC plays the entire file. I just tried to play the file in Quicktime and discovered that it is doing what Toast is doing. Basically only reading the .avi to the 1 hour and 26 minute point. It does not think there is anything past that (although there is!).
Anyone have a suggestion? Is there something in quicktime that only allows the .avi to be 1 hour 26 minutes long? How can i get around this?
Originally Posted by Traumamc
https://forum.videohelp.com/viewtopic.php?t=293905
And if you do some searching, I'm sure you can find posts about it from a very long time ago.
Another recent post;
https://forum.videohelp.com/viewtopic.php?p=1530605&highlight=#1530605
Since this happens in QuickTime, it's probably going to happen in any App that uses QT to work with AVIs, that includes Toast, MPEG Streamclip, Real Media Player, and many more. It also affects ffmpegX in the Same Way. Drop that new AVI into ffmpegX and I'll bet you it only sees 86 minutes of movie. Try doing a ffmpegX Video Passthrough on that new AVI and you will also only get the first 1GB of audio/video out of ffmpegX.
BTW, the fix mentioned in my first link still works with D-Vision 3.2.2. There appears to be a bug in the Audio Direct Stream Copy part of D-Vision so I still recommend using ffmpegX to extract the Audio track from the original AVI for use in D-Vision.
It would be nice if these bugs were fixed....
avi to dvd in toast 9
By levi747 in forum MacReplies: 4Last Post: 2nd May 2008, 21:43 -
Post deleted since I figured it out
By denise4gb in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2008, 22:29 -
Figured Out 'RATATOUILLE', menus and all
By theizzlesin2005 in forum DVD RippingReplies: 39Last Post: 11th Feb 2008, 08:48 -
AVI file to DVD using Toast 8.0
By Huntr777 in forum MacReplies: 7Last Post: 29th Jun 2007, 08:24 -
anyone figured out apocalypto yet?
By steamedPS in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 14:06
