I'm looking for a tool to display information of a DVD video disc and especially video and audio bitrate,cause i need to know in what quality my dvd deck recorder records in.
Results 1 to 11 of 11
The Teco Bitrate Viewer (http://www.tecoltd.com) can do this and I think this is what levick is talking about. While I do like and use Gspot, in my experience it not always a great tool for looking at MPEG files. Several times I've used it to look at an MPEG file and had it return absolutely nothing useful about the bitrate of the audio or video.
Thanks jman98! That is what I should have typed!
Virtualdub Mpeg will also give good infomation. -
Just let me tell you that you set recording mode in hours.ITs mode 1 called "m1" with total duration of 1 hour,then m2,m2.5 m3 m4 and m6.
So how much is like 1hour mpeg2 4.37gb and 2 hours 4.37gb.IT's just math,even a dvd bitrate calculator could give me a bitrate,is there one for this specific use?
Thanx for your answers. -
If you wanted to get a general idea of what bitrates your player would use (assuming no further information given on your recorder makers website), you could try a tool like VideoCalc and input times, audio bitrate (if known/check in GSpot etc), and set for DVD5.. Short of more detailed recording mode info on the makers site, this should give you a somewhat accurate guess as to what the leels would be.
If in doubt, Google it.
MPEGProperties - It does video: resolution, fps, bitrate etc. and audio: codec and bitrate etc.
And it's free.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Print DVD Information (VTS - PGC)
By dw-wizard in forum DVD RippingReplies: 0Last Post: 27th Sep 2010, 14:54 -
dvd information
By ht0160 in forum Authoring (DVD)Replies: 2Last Post: 11th May 2010, 14:40 -
Question about incorrect DVD information given by Gspot
By jimdagys in forum DVD RippingReplies: 2Last Post: 9th Dec 2009, 00:24 -
General information on how DVD players and their firmware (or software)
By Samazama in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2009, 16:51 -
Title Information Doubled-up using Linux DVD tools
By jblack in forum DVD RippingReplies: 0Last Post: 10th Apr 2009, 22:04
