I use dvd+rw media to record from my deck dvd recorder fro satelite channels.
What i want,is a way to demux any given title of a dvd to one singkle file for further editing.
So far i demux each individual stream wirth ifo mode of dvd decrypter,but i want everything to be stored in one single file.
I don't know any app that can rip titles to one mpg...
but you could rip everything using vob2mpg.
or you could multiplex the streams to one mpg with ImagoMPEG-Muxer. -
I tried some methods but they take lot of time.
The one i use,is demux pgc with rejig,and mux to .mpg with imago.
Another one is decrypt vobs with decrypter then merge to one with vob2mpg and then import to videoredo cut commercials and save as mpeg.
But they all take time,isn't there one for sure,that demux streams and saves as an mpg,all in one take? -
Easiest way to an mpeg would probably be mencoder -dvd-device x: dvd://1 -ovc copy -oac copy -of mpeg -o out.mpg
Can't see why you can't use DVD Decrypter in IFO mode to create a single VOB though. -
How do you create one single vob?Decrypter saves video stream as an m2v file and then saves audio as an .ac3 file,and i then have to mux them.
How do you demux them video+audio into a single .vob file?That would do it for me! -
Set up DVD Decrypter in IFO Mode and set File Splitting to None, and don't touch Stream Processing. -
So i don't enable stream processing and i have all streams into one file?OK easy,thanx.
2 more things:
A)Y do pgs come up twice on my dvd-vrs?
B)Also dvd decrypter always shows a subtitle stream although the dvd has none,only audio/video/chapters.
Editing DVD chapters into a single title
By matthewjohn23 in forum Authoring (DVD)Replies: 6Last Post: 20th Nov 2013, 23:24 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
how to demux main IFO pgc title to 1 single VOB?
By deejay.2001 in forum DVD RippingReplies: 6Last Post: 24th Apr 2011, 19:21 -
How to get a DVD title into a single file
By Case in forum ffmpegX general discussionReplies: 5Last Post: 21st Apr 2009, 04:28 -
DVD main title to single file, with AC3/DTS
By knight76 in forum DVD RippingReplies: 5Last Post: 27th Feb 2009, 10:30
