Here is my first problem: http://forum.videolan.org/viewtopic.php?t=22656. I found that the thread was exactly fitting my problem so I decided to redirect it to you guys and add some comments to clarify the issue. Second problem is of little concern and only happens when using DXMAN. Some days ago, I wanted to get rid of a few Nero Plugins and went through the usual uninstallation process. Then wanting to make sure everything was uninstalled, I performed a few checks. First thing I noticed when using Sherlock, was that two of my Nero Plugins codec files were missing. This was normal due to the fact I uninstalled them. So I tried removing those missing file issues using DXMAN, but uninstalled Nero 7 first and then nothing would happen when trying to uninstall the plugins with DXMAN. Then I used Nero's General Clean Tool to remove all Nero's registries entries, came back to DXMAN and the missing files were still there even if Sherlock would tell me everything was uninstalled. So is it just DXMAN or am I really unable to completely get rid of the plugins?
It looks like the VideoLan forum covered a lot of the possible cures or causes. I run VLC on several different computers and I haven't seen that behavior. I also use Zoom Player. I rarely use WMP or MPC. It sounds like there is a particular set of circumstances or settings that are causing it, maybe someone else here has encountered it.
The Nero problem may be a byproduct of Nero 7. It seems to have had quite a few bugs, mostly cured, but a few may remain. I still run 6.6 and have no urge to upgrade unless forced.
I have no idea what I'm doing, but solved the choppy video by installing the Code K-Lite package. Left all the default setting since I don't know anything.
Everything plays perfectly now. -
I would try ccleaner to flush any leftovers from the registry, which may or may not fix your DXMan problems.
I would not, under any circumstances, install a codec pack.
I certainly haven't experienced any playback issues with VLC, however I usually use The KM Player now anyway. That said, VLC is regularly updated, so make sure you are running the latest version.Read my blog here.
Some people buy a lottery ticket and win a lot of money. Most people don't. You are one of the lucky few who have had K-Lite actually solve a problem. The vast majority of posts here about it require people to uninstall it to fix problems. It almost never solves any problems.Originally Posted by emptyset
Choppy video playback.
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd May 2014, 02:16 -
choppy video playback
By RobotFood in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 08:40 -
playback stutter on recode and dvdshrink, none on vlc, nero showtime etc
By RdM642 in forum DVD RippingReplies: 4Last Post: 15th Feb 2008, 13:15 -
Choppy Video using VLC to view multicast Mpeg4 stream
By slaiche in forum Newbie / General discussionsReplies: 5Last Post: 24th Oct 2007, 10:30 -
Choppy playback using nero.
By compduce in forum Video ConversionReplies: 5Last Post: 24th Jul 2007, 00:21
