Here is my project.
I have one clip or title. I just want to put it on a dvd and loop it. Basically 15 minutes over and over and over until it is turned off or ejected. No menu.
Thanks in advance.
Jim
Jim
DVDauthorgui or guifordvdauthor would be the vheapest iont. You don't nned a menu, just the ability to lnk the end to the start of the same clip.
Or download the demo of DVD Lab Pro. Very simple to do.Read my blog here.
Ulead DVD Movie Factory is simple, and quite forgiving on video. Earlier version already good (in fact, I still use version 2 for most of my job; current is version 5.) Can be found at Ebay for below $5. Yes, it can loop video.
In DVDWS2, you would make the video the menu. It would be a menu that loops forever.
Simplest DVD authoring program?
By paristideu in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2011, 12:08 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 22:43 -
new authoring program, Bombono DVD
By ilya in forum LinuxReplies: 25Last Post: 19th Sep 2009, 15:11 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 15:25 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 05:10
