I use TMPGEnc DVD Author to open the VIDEO_TS folder I have previously copied to the PC's hard drive. I edit the track to remove unwanted material. Now, the track is made up of individual clips. I re-author the DVD and create a DVD-R which plays fine on my home Panasonic DVD player. However, I see a second pause between the end of one clip and the beginning of the next at the place where I had edited (removed) the material I did not want. Is there a way to prevent the pause? I am looking for a continuous, uninterrupted playback. If I edit the track using the Panasonic home recorder and I create a DVD-R using the Panasonic, I do not see the pause where the removed material was.
Thank you,
Edwin
I overlooked to mention I have an extensive library of freeware/shareware and commercial products. I would try different tools if it would solve the problem.
Remove Small Section of Center Channel from Stereo Track
By EmpireStrikesBack198 in forum AudioReplies: 14Last Post: 31st Jul 2011, 12:48 -
2 small questions about authoring with IFOEDIT
By i_j_2009 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 10:15 -
Add audio-track to DVD WITHOUT re-authoring
By vk_dk in forum DVD RippingReplies: 1Last Post: 14th May 2010, 19:57 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 05:59 -
Adding a MIDI track while authoring?
By dondeaida in forum Authoring (DVD)Replies: 3Last Post: 21st Aug 2007, 20:11
