I am trying to convert the main movie VOBs of The Incredibles to MPEG. I do a main movie only rip with Decrypter, playback of the resultant VOBs in PowerDVD is perfect. I process the VOBs with VOB2MPEG, the resultant MPEG has alot of skips in playback and has a lot of pixelation artifacts when I playback with WMP.
What can be done to determine the problem and resolve it? Thanks.
Results 1 to 9 of 9
Haven't tried other players. From MPEG I am converting to WMV-HD with Windows Media Encoder, and the WMV file has the same problem as the MPEG. Codec issue maybe?
I have a new version which you are welcome to try to see if that issue is gone. Drop me an email...
ChrissyBoy,
I tried the new version you send me (thanks!) but unfortunately the same problem exists. -
I am trying to convert the MPEG to WMV-HD with Windows Media Encoder, and because WME uses the same subsystem to import that WMP uses for playback, the playback issues are prevalent in the import and subsequent conversion.
What is the most recommended freeware MPEG2 codec that is WMP compatible? I've tried nVidia PureVideo, but I can't seem to make WMP use that codec for MPEG2 files, only for DVDs. -
Just an FYI, I tried de-muxing the video and audio separate, then re-muxing to am MPEG file with Imago-MPEGMuxer. Playback is perfect.
Registration Issue VOB2MPG
By spysmily1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 12th Jan 2011, 14:03 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
VOB2MPG PRO audio sync issue
By wriggley in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Feb 2010, 17:19 -
Working with VOB2MPG: speed issue hint
By cdgmol in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 31st Jul 2009, 18:57 -
vob2mpg sound issue with certain DVDs
By YoKnows in forum DVD RippingReplies: 1Last Post: 31st Jul 2007, 20:10
