Does anyone know what the Pulldown Option does in CCE SE?
My video is in PAL, and I want to encode it to MPEG-2 to put it on a DVD.
Thanks!
Hi,
I may be wrong, but I believe it's used for video that's got a framerate of 23.976 fps and is being encoded to MPEG with a framerate of 29.97 fps (the numbers might not be spot on). Ticking the "pulldown" flag in any encoder, again "I believe", does something to the frames to get from 23.976 to 29.97 fps.
As these numbers only relate to NTSC material, and you have PAL, I'd say you could ignore it.
This is from the glossary - the link is in the top left of the page.
www.videohelp.com/glossary?P#PULLDOWNThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 17:53 -
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
Correct pulldown or not
By carlmart in forum Video ConversionReplies: 2Last Post: 1st Feb 2009, 20:25 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 07:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 04:25
