trying to burn a iso file, there is no autorun file?
Results 1 to 9 of 9
In your burning software, select disc image - then select the iso file and burn away.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Then you probably have a corrupt file.
...Okay, I'll ask:
What burning program are you using?
What type of system are you using (OS, hardware (CPU, memory, hard drive space, and your CD/DVD burner))?
What size ISO are you trying to burn? To a blank CD, or a blank DVD?
Is having an autorun file on the disc image important? Not all CDs and DVDs have one (and likewise, the disc images).If cameras add ten pounds, why would people want to eat them? -
The autorun.inf file is what makes the CD (or DVD) "do something" on insert (provided autorun is still enabled on your CD or DVD-ROM). It is in no way relevant to the burning process, and is not required at all - just an easier way to access the intended start point on the disc without having to hunt for the files manually.
"that doesn't work" doesn't really help anyone. I can't see your screen from here, and I don't think anyone else can either. So you might need to give us a little leg up and tell us what program you're using for burning, what error message you get, maybe how you created the iso file, and why you're enquiring about an autorun file ?If in doubt, Google it. -
HI, I have burned many an Iso's but today I seem to be having a problem...is there a way tp check if the iso is corrupted.
Raz
How do i get an iso to burn properly?
By EdJr in forum Newbie / General discussionsReplies: 36Last Post: 23rd Jan 2012, 17:37 -
How to Burn an ISO on the Mac
By Jeff_NJ in forum MacReplies: 6Last Post: 19th Nov 2008, 10:11 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 15:13 -
How to burn a ISO file on a Mac? Can this be done?
By babybreese in forum MacReplies: 9Last Post: 30th Aug 2007, 21:45 -
Burn a cd iso to dvd?
By jimminy_kriket in forum Newbie / General discussionsReplies: 6Last Post: 4th Jul 2007, 01:41
