Im working on a machine with only three harddrives and I am wanting to use them in a striped array. My question is, is there any way possible I can have striping with redundancy useing only three drives? I know of Raid 01, but Im told there must be four drives.
:ונעדי ימ אוה שנאו לכמ בלה בקע
If you have a controller that supports it, RAID 5 will give you striping with parity which will give you redundancy, BUT you will sacrifice 1 drive's storage space to do so.
e.g - (3) 250GB drives in a RAID 5 array = 500GB storage space. It is fault tolerant and even if one of the drives fails you will not lose your data.
http://en.wikipedia.org/wiki/Redundant_array_of_independent_disks#RAID_5Nothing can stop me now, 'cause I don't care anymore. -
I hope you're not including your OS/Boot drive in that list. It should be separate (best fault tolerance for it would probably be Mirroring).
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 05:13 -
Chip Choices and Raid Arrays
By Sckinhunter in forum ComputerReplies: 13Last Post: 30th Mar 2011, 22:02 -
RAID considerations
By rallynavvie in forum ComputerReplies: 41Last Post: 2nd Nov 2009, 20:55 -
Raid 5 to Raid 1
By mysts in forum ComputerReplies: 4Last Post: 14th Mar 2009, 00:36 -
Using Raid 0 for Rendering?
By jaffacaique in forum EditingReplies: 7Last Post: 3rd Aug 2008, 19:32
