I searched the forums but did not find anything on this message....maybe you all can help me...
Im getting a burn error message reading..burn error/:cannot connect to trf..
Then it gives me the list that it went through before it stopped burning....heres the message
1A20*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder: <LITE-ON DVDRW SOHW-1613S>Version: AS06 - HA 1 TA 1 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TOSHIBA DVD-ROM SD-M1612 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SOHW-1613S atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
TOSHIBA DVD-ROM SD-M1612 F: CDRom0
LITE-ON DVDRW SOHW-1613S G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 36700160 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 223MB (228896kB)
Free physical memory: 90MB (92508kB)
Memory in use : 59 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.7.2006
NeroAPI
8:25:12 PM #1 Phase 112 File APIProgress.cpp, Line 275
DVD-Video files reallocation started
8:25:12 PM #2 Phase 114 File APIProgress.cpp, Line 275
DVD-Video files reallocation completed (no file modified)
8:25:12 PM #3 Phase 111 File APIProgress.cpp, Line 275
DVD-Video files sorted
8:25:12 PM #4 NEROAPI 7 File Burncd.cpp, Line 3095
Error:\nCannot connect TRF.
8:25:12 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
8:25:12 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.38a, size=16288 bytes, created 4/18/2002 4:02:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
THANKS IN ADVANCE
Are you using Nero to burn a Shrink file? That error happens with the later versions of Nero and DVD Shrink. You can revert to an older version of Nero, available on their website. Use Nero Clean Tool to remove the remnants of Nero, then install an older version. Or use IMGBurn or DVD Decrypter to burn from Shrink.
If not, then do a Google search for 'cannot connect to trf' and you will get some hits. -
You can also just burn manually from Nero from the Shrink files. I had the same problem - and that's my work around for now.
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 12:17 -
[ASK] Error Burn BD with Imgburn
By m1x in forum Blu-ray RippingReplies: 5Last Post: 30th Jun 2010, 12:25 -
Canon HF200 - Cannot Connect to Battery Error
By peteyy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Dec 2009, 14:24 -
Error when trying to burn
By arose1179 in forum Newbie / General discussionsReplies: 6Last Post: 16th Oct 2008, 17:12 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58
