Whenever I convert a video from MPEG to WMV I just get a black screen with no picture, but I can hear the audio playing. I've tried lots of converters and I've downloaded lots of codecs to try to solve this problem, but nothing has helped. Help me please!
Results 1 to 11 of 11
Try windows movie maker. Works like a charm and its free
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I tried it and it just let me convert the audio file, so basically the same result.
Well there are other video file types out there. Have you tried divx? Why do you need just wmv? Sometimes I find it easier to use an alternative than to keep pushing with a problem.
The same thing happened to me on an old Windows install,I think it has to do with the codecs.When I reinstalled Windows(without PowerDVD) WMM worked perfectly,make sure you don't have the Cyberlink MPEG-2 codec installed.
You might try Super,Ulead VideoStudio or ArcSoft Showbiz. -
Im trying to upload them a website and they have to have a small file size. I don't think you can upload divx files to it either. It's weird because the first time I converted it, it worked, then it just stopped working.Originally Posted by yoda313
You can download and install the WMV9 VCM. Get it here:
https://www.microsoft.com/windows/windowsmedia/forpros/codecs/video.aspx#WindowsMediaVideo9VCM
Then open the mpeg in Virtualdub-mpeg2 and save the AVI using WMV9 compression. Make sure to also use compression for Audio. You can use mp3 if you want.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
Windows Media Encoder and a good mpeg2 decoder like powerdvd!
dipstick: i had problem playing avi with wmv9 using some players...can you remux to wmv container? -
Baldrick wrote:
I'm pretty sure if you use Virtualdub with the wmv9 VCM, that you have to save as AVI with wmv9 codec. Virtualdub only allows saving to AVI.dipstick: i had problem playing avi with wmv9 using some players...can you remux to wmv container?
It may not play in all players, I've only tested Windows Media Player, MPC, Nero, even Irfanview. It works fine for me and everyone I've sent clips to.
Here's an example of an AVI encoded with wmv9 vcm. See if it plays fine for you. No audio, only video.
wmvslow.aviI stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
yep, works fine now with wmp 10 and mpc...I tested it some years ago...
but I can't find the vcm codec at https://www.microsoft.com/windows/windowsmedia/forpros/codecs/video.aspx
but here http://www.free-codecs.com/Windows_Media_Video_VCM_download.htm
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 23:24 -
WMV to DVD+R DL troubles :(
By mastarifla in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2008, 18:45 -
Troubles with avi to wmv
By masadar in forum Video ConversionReplies: 2Last Post: 28th Sep 2008, 22:33 -
WMV to AVI Converstion Troubles
By BassJunkie in forum MacReplies: 3Last Post: 16th May 2008, 15:10
