The program I have (DVD Architect) to create DVDs compresses files that are used, so is it a good idea to use AVI or MPEG-2 files? I was told before that for DVD making, video files must be MPEG-2, but wouldn't using that format lose quality since, in the process, rendering a DVD compresses all files?
https://www.videohelp.com/dvd
That link might help a little.
What authoring programs do is take a dvd compatible mpeg2 and put in the proper dvd structure. This means it makes vob files and ifo and bup files in a video_ts folder (the audio_ts folder is empty when its created for dvd-video).
If you are making a true dvd video you have no choice but to end up at mpeg2 one way or another. Even if your authoring program accepts avi files it is converting it to mpeg2 before it makes the folders.
Assuming your using your own material you should encode to the proper bitrate for dvd creation first. If your taking an avi you recorded and are making a mpeg2 you need to make sure it will fit a single layer dvdr or a double layer dvdr if you have a dl burner and dl blanks.
You must have mpeg 2 to make a dvd. No way around it in the long run.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
So if I use an MPEG-2 file, would the program skip the conversion process since it's already in MPEG-2?
Most authoring software allows you to choose a profile to use while authoring the disc. Some are as simple as VCR settings (SP, LP, SLP), others are more advanced and you often have the option to create your own profile. If your input files meet the criteria of the profile that you chose, then no conversion will be performed. If the files are different, then conversion is performed.
Google is your Friend -
If the mpeg-2 is within the DVD specs, and if the authoring app hasn't its own opinion on what is DVD compliant and not.Originally Posted by seven_deuce offsuit
Best is to make sure that the mpeg is a valid DVD specs mpg, and never use an authoring app that has built in encoding capabilities, but simply refuses to accept (or at least warn you of) non compliant source material.
/Mats -
DVD Architect 3 - go File / Optimize DVD
in the popup window, click on the video title in question, then on the right side where you see GENERAL / VIDEO 1 / AUDIO 1 -- click on the VIDEO tab, and there will be info on whether DVDA thinks it is compliant (if it is compliant, you have a choice to use it "asis", or convert it to project settings, or a specific setting for that asset).
Regards,
George
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 08:47 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
A Question About Making and Selling Videos Online
By Polar Bear Guy in forum Newbie / General discussionsReplies: 14Last Post: 22nd Nov 2007, 05:42 -
making dvd;s
By brenjim in forum Capturing and VCRReplies: 2Last Post: 14th Jul 2007, 12:48 -
Question regarding making an existing video larger
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2007, 10:15
