Just curious.. through reading some posts, I have gotten the impression that (x)VCD's will (might?) play with a VBR rather than the constant 1150. Makes sense to me as far as in a DVD player.. since they're basically built around VBR. But how likely is this to work?. I know the MPEG2 is inherently a VBR scheme, but would set-top DVD players be 'wired' to decode a VBR MP1 stream, seeing as how the MP1 standard is for a 1150 CBR?
How much forethought do the manufacturers *really* have?
Thanks!
-squeak
http://djsqueak.djcentral.com -
Well, already done
My SeVCD Template uses MPEG1 VBR @1150kbps, so it does work, how well, depends on the compatibility of the DVD player itself it should be very compatible, but not 100%
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
FFMPEG MPEG-2 VBR output size not coming out as expected
By DJRumpy in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 09:19 -
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 14:12 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
mpeg 4 realtime bitrates vs multipass mpeg-2 VBR
By miamicanes in forum Capturing and VCRReplies: 5Last Post: 9th Sep 2007, 21:37 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 14:28
