Create Midi Disc To Play On Karaoke Player
I bought a karaoke midi player that includes a midi disc that contains 7,700 karaoke songs with different video clips on its background. Sad to say, there were songs that I really liked which were not included on the midi disc. I have these songs on my computer on midi and kar file types. Now, I'm wondering how do I create a midi disc which could play on my karaoke midi player. (The player wherein you also have a karaoke songbook where you will find the song, then you put the corresponding number of the song using the remote control to play it) I searched the internet but there were no discussions pertaining to this. Does anyone know how to deal with it?
By the way, the karaoke that I bought was Karavision DVD - MiDi Karaoke System KMD-9800. Here's a webpage with the details of the player:
http://in-cebu.net/cac/product_info.php?products_id=354
I hope someone would know how to make a midi disc. Thank you.
I got the above post from another site.My friend has one of this and asked me to make a backup of the disc which I did.I tried to access the content of the dvd to see all the songs in it but it wont show.. It only shows 3 folder one audio w/c is empty, one video_ts with 3.25 g on it,and a midio file with 3 sub folder Fontw/ 7.46 mb, fyphph w/749 mb, and info w/ 749 mb, all
are in DAT file.I need help to access those songs so i can create or turn them into a vcd karaoke..Thanks
There's only so much you can do with this type of machine (e.g. swapping bkgd graphics).
Read my past posts on the same subject...
edit: ***Note---these are Proprietary formats. That makes it much harder to reverse engineer. -
Thanks..Can you show me where is the post about this....I cant find it
Again thanks for the quick reply. Maybe I'll just play the song that i want record it thru my dv cam and then maybe i can convert it into a vcd karaoke or mpeg... -
Here: https://forum.videohelp.com/viewtopic.php?t=298684&highlight=karaoke
and
Here: https://forum.videohelp.com/viewtopic.php?t=256335&highlight=karaoke
(This older one also had some later PMs involving using CDMage, CDCvt, etc to Hexedit a CD discImage into including the material the OP wanted to include/replace, so it's slightly OT here)
HTH,
Scott -
Yes those are good info. Really appreciate it a lot...so thats it theres no way i would be able to access those song unless i know the program that creates it...propriety formats ...interesting
Thanks C
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 10:02 -
help, trying to copy midi dvd karaoke
By chris_j11 in forum DVD RippingReplies: 17Last Post: 24th Jul 2008, 10:11 -
Try to backing up Midi DVD Karaoke
By Kennytran in forum DVD RippingReplies: 18Last Post: 27th Sep 2007, 12:11 -
MIDI DVD karaoke player software
By baodownnow in forum Software PlayingReplies: 2Last Post: 1st Aug 2007, 20:15 -
MIDI DVD Karaoke Player 40,000 Songs with High Definition TV out, DIVX, USB
By Manokat in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jun 2007, 05:26
