Hello guys,
I am looking for a software which will allow me to open a .DAT file, swap its left-right audio channels around and re-encode the file into .DAT again without loss of quality or significant differences in file size between the original and resulting file.
It would be preferable if the software is standalone ie: it does that without the need for using another software to seperate the audio channels first, etc. etc.
Thanks guys,
Warm Regards.
cyclonite.
no such software,
convert the dat to a mpg with vcdgear
open the mpg in goldwave and switch channels and save as wav
convert to mpa/mp2 with ffmpeggui
add back the new audio with the old mpg with tmpgenc, file->mpeg tools->simple multiplex
make a new vcd from the mpg to create a new vcd with a dat file.
and I assume that you are talking about a dat from a vcd .... -
If you just want to swap L/R channels, you could just exchange the RCA leads. Take it as a joke if you like, but it would solve the problem. I've done that for the connectors to my headphones, which are more comfortable worn backwards...
how to seperate audio from DAT file
By pcb in forum AudioReplies: 5Last Post: 4th Jul 2011, 14:51 -
How to separate audio from left/right channels from a video file for free?
By gutterboy in forum AudioReplies: 9Last Post: 26th Jun 2011, 13:24 -
more video & audio channels in WMV file
By fixme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2010, 10:52 -
Problem convert DVD file to xvid with combine audio channels
By Aquatoid in forum Video ConversionReplies: 5Last Post: 26th Feb 2010, 16:45 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31
