Results 1 to 10 of 10
  1. See http://uninstall.settec.com/eng/ and http://securityresponse.symantec.com/avcenter/reference/stories.from.the.drm.world.pdf
    This can install even if autorun is off and it turns off anyDVD and other programs that prevent it from working. The remaoval tool didn't work for me, trying other non-specific tools. BTW I never agreed to the EULA (and never saw it).
  2. Originally Posted by docrhody
    This can install even if autorun is off.
    You misunderstood.
    In the pdf, it states that autorun is enabled.
    It cannot install unless something triggers it, in this case, autorun is enabled.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Not to mention this "Mr. & Mrs. SMith" from over there & this "rootkit" is kind of old new's.....
  4. I had this virus (dll file), apparently it was exploited by a Trojan I picked up. I had to use ewido to clean it (it reinstalled for about a week-then was no longer detected), then the problem was solved when I updated anyDVD. Now I can play DVDs fine.
    The "virus" dumps the dll file to a temp directory even if autorun is off. It stays there even if the eula is refused, the trojan that activated it was from an internet file I tried to install called zipcodec.
  5. Originally Posted by docrhody
    If autorun is disabled, you do not see a eula.
  6. Banned
    Feb 2005
    USA
    How does something install itself if auto run is disabled?
  7. Originally Posted by ROF
    That is my question as well.
    Apr 2003
    Maryland
    Apparently, from what I read, it copies itself to a temp folder regardless of whether you agree or not to the initital pop up window that opens upon insertion of the DVD. If you say yes, it installs it. If you say no, it still stays in the temp folders and then from there, some maliciousl software ( virus / trojan ) will use it in some form.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  9. Originally Posted by jtoolman2000
    If autorun is disabled, nothing runs. Nothing installs. Nothing happens. No popup screen-
  10. Banned
    Feb 2005
    USA
    From what I read, and have now confirmed, my anti-virus provider (McAfee) protects me from the .dll file. Of course, as it states in the article, if you have auto-run turned off, this will not install in the first place.
