On VCDHELP's guide on how to convert divx to svcd is says the following:
Configure the Advanced:
Select Source Aspect Ratio select 1:1 (VGA) (if your source is in 4:3 select 4:3 525 line(NTSC) for NTSC and 4:3 625 line(PAL) for PAL).
and under Video Arange Method Full screen(keep aspect ratio).
I am confused on which ratio to use if i dont know what the aspect ratio is of the film i am encoding (i get them of the net)
Is there a way on finding out what the aspect ratio is of a certain file, so that i can select the right one.
Thanks in advance
Benny!
If the source is divx just select 1:1(VGA) and full screen[keep aspect ratio].
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 09:35 -
No aspect ratio 5/4 in Tmpgenc Xpress
By sychern in forum Video ConversionReplies: 1Last Post: 29th Sep 2008, 03:06 -
Tmpgenc xpress Image Resolution & aspect ratio
By sychern in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 08:25 -
16.9 Aspect Ratio with TMPGEnc dvd author 1.6
By GJF in forum Authoring (DVD)Replies: 22Last Post: 24th Jun 2008, 03:57 -
Tmpgenc Express: Aspect ratio problem
By shashidar in forum Video ConversionReplies: 1Last Post: 11th Mar 2008, 18:59
