I've been DL burning for a year now, but not doing much in the way of DL authoring.
I just wanted to confirm that authoring with Ulead DVD Workshop 2 and burning with the PgcEdit method outlined in the guides works perfectly.
It was fast and required very little interaction. You don't need to be a techie to use PgcEdit for this narrow usage, regardless of how hard or complex the software looks.
This guide for burning the authored disc:
http://www.digital-digest.com/~blutach/dl_burn_guide2/dl_burning_with_pgcedit_v2.htm#BurnSetup
This was used for several smaller titles on a single disc (an "episode" disc, not one long movie).
Just author a folder in DVDWS2, not an image or disc.
Spare yourself headaches and use MKM (Verbatim) DVD+R DL media.
Oh yeah, two special notes for DVDWS users.
1 -- Go to your authored folder and delete the DWS_TS folder. Otherwise you'll get weird errors and the program might crash.
2 -- When you open the DVD, this weird box will appear and tell you it found 0 links or something. It'll give the option to scan or close. Close it.Want my help? Ask here! (not via PM!)
absolutely smurf. The key piece in the puzzle here is pgcedit without a doubt. I have tried copytodvd and recordnow with mixed successes and now wished I had found the pgcedit trick before using those other tools. I use DVD-lab Studio then open up authored DVD folder is pgcedit, allow pgcedit to find proper layer break point and then burn the ISO image with IMGBurn (using Verbatim DL discs). Using this method for the better part of 2 months now and happy to report the earth is back on its axis thanks to pgcedit
PGCEdit question
By gbabione in forum EditingReplies: 14Last Post: 27th Feb 2012, 22:21 -
PGCEdit Question
By billynews in forum DVD RippingReplies: 5Last Post: 17th Oct 2011, 05:02 -
PGCEdit menu editing
By gbabione in forum DVD RippingReplies: 3Last Post: 31st Aug 2010, 06:13 -
DVDWS2 & Win7 Home Premium audio problem
By ia2azbound in forum Authoring (DVD)Replies: 4Last Post: 20th Nov 2009, 20:44 -
PgcEdit questions
By kshavo in forum Authoring (DVD)Replies: 9Last Post: 15th May 2007, 03:18
