Hi guys (and ladies),
I have a problem - bought a DVD recently and guess what, there is a Russian translation on top of the audio stream so all I can hear is 'Da,da,net,net,molotov...'. I'm sure it was put on top of the original audio file, so...is there a way to get rid of this annoying translation?
Thanks for your help.
no, https://forum.videohelp.com/viewtopic.php?p=1476868#1476868
but if you want to try filter it out use pgcdemux or dvddecrypter to rip out the audio and use an audio editor....but it is not worth it. -
The only thing I can think of is that if you could find the audio for it in its original language somewhere, then you could re-author your DVD using the new audio while keeping the DVD video quality, menus, etc., providing you have a DVD burner.
I did this once when the DVD I bought had a heavily censored soundtrack. I found an .avi file of the film with original audio, and reauthored my DVD. It took some work, but I did it. -
No, what's overwritten is overwritten.
As others said, if you find the original language sound track somewhere you can extract that and reauthor the DVD, but not worth the trouble, if you got it extra-legally the first place.
How to extract stream URL
By masster in forum Video Streaming DownloadingReplies: 21Last Post: 16th Apr 2018, 11:51 -
Can not extract PGS stream from MKV file
By gonzalu in forum SubtitleReplies: 27Last Post: 19th Aug 2016, 03:48 -
Cannot extract an h264 out of a transport stream (.ts --> .mp4)
By dirk205 in forum Video ConversionReplies: 0Last Post: 13th Sep 2011, 02:39 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 17:42 -
Extract problem dolby audio from transport stream
By DVWannaB in forum Video ConversionReplies: 7Last Post: 17th Aug 2007, 22:35
