hi all. i have a bunch of DiVX movies that are 14.97 (i think the .97 is right) and i want to convert to VCD. i tried a couple different bitrates and of course they are blocky. is this just going to be a case of "crap in crap out"... or is there a way to make them look half ways decent? somehow i doubt it but i would like to hear from you?
thanks.
-Mark
Did you follow the guide at http://www.vcdhelp.com/tmpgenc.htm?
Yes Divx is slow frame rate so it will not be the quality of DVD. -
DivX is not "slow frame rate".
DivX is a way of encoding and decoding video. Properties such as frame rate/bitrate/resolutions etc.. are entirely configurable within the DivX codec.
An NTSC standard movie should have a frame rate of 29.97. If your DivX movies REALLY are 14fps then the movie will look jumpy (but not necessarily blocky) and there will be all sorts of sync problems with the audio.
I suspect that your DivX movies do actually have the correct fps (29.97) and that you have just read off the wrong piece of information.
As z68h said, VCDs encoded from a DivX source are never going to be the greatest quality due to DivX being a lossy format (especially at low bitrates). You should however be able to obtain satisfactory VCD quality if you play around with some settings in TMPGENC. I seem to remember that there was a thread in this forum which discussed how to best set up TMGENC to encode from DivX. If you can dig it out then it might be useful.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
