Ok I recently obtained this HD rip which is an .mkv.. and i'm having problems ripping the audio from the video.. the video plays in every player fine.. but will not let me rip the audio.. I have the Klite 2.7 Full codec pack installed and I am using Virtualdubmod to try and rip the audio into .wav so I can time subtitles (its a japanese television show)
This is what I get when I run the .mkv through MatroskaDiag
Matroska file info : C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv
File size : 351.26 MB
File complete : yes
Duration : 00:23:39.669
Writing application : mkvmerge v1.6.5 ('Watcher Of The Skies') built on Dec 7 2005 18:53:53
Muxing application : libebml v0.7.6 + libmatroska v0.8.0
Date : 2005-07-09 07:13:10.000
Tracks : 2
Track 1 : Video
Codec : Microsoft VFW compatibility mode (V_MS/VFW/FOURCC)
Fourcc : Windows Media Video V9 (WMV3)
Language : Undetermined (und)
Pixel Width : 1280
Pixel Height : 720
Track 2 : Audio
Codec : AAC Low Complexity (A_AAC/MPEG4/LC)
Possible filter : CoreAAC
Installed : yes, in C:\Program Files\K-Lite Codec Pack\filters\CoreAAC.ax (1.2.0.573)
Link : http://coreaac.corecodec.org
Sampling Frequency : 48000
Channels : 2
DirectShow RenderFile check :
Matroska Splitter : Gabest's Matroska Splitter
Installed : no
Can be created : no
Matroska Splitter : Haali's New Matroska Splitter
Installed : yes, in C:\Program Files\Matroska Pack\haali\splitter.ax
Can be created : yes
RenderFile with DirectShow : OK
DirectShow detailed rendering :
0> MyRenderFile : C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv
0> Creation of GraphBuilder : OK
0> Creation of FilterMapper2 : OK
47> Adding graph to ROT : OK
219> Creation of source filter : OK
219> # Rendering output pin C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv(Video)
219> Filters matching mediatype : ffdshow MPEG-4 Video Decoder, DirectVobSub (auto-loading version), Video Renderer, WMVideo Decoder DMO, AVI Decompressor
219> Trying connection to ffdshow MPEG-4 Video Decoder :
234> Failed connecting pin to ffdshow MPEG-4 Video Decoder, removing it now.
234> Trying connection to DirectVobSub (auto-loading version) :
234> Failed connecting pin to DirectVobSub (auto-loading version), removing it now.
234> Trying connection to Video Renderer :
265> Failed connecting pin to Video Renderer, removing it now.
265> Trying connection to WMVideo Decoder DMO :
297> OK, connected to (in0)WMVideo Decoder DMO
297> # Rendering output pin C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv(Video) -> WMVideo Decoder DMO(out0)
297> Filters matching mediatype : ffdshow MPEG-4 Video Decoder, DirectVobSub (auto-loading version), Video Renderer, AVI Decompressor
297> Trying connection to ffdshow MPEG-4 Video Decoder :
297> Failed connecting pin to ffdshow MPEG-4 Video Decoder, removing it now.
297> Trying connection to DirectVobSub (auto-loading version) :
312> Failed connecting pin to DirectVobSub (auto-loading version), removing it now.
312> Trying connection to Video Renderer :
375> OK, connected to (VMR Input0)Video Renderer
375> Completed path : C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv(Video) -> WMVideo Decoder DMO(out0) -> Video Renderer
375> # Rendering output pin C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv(Audio)
375> Filters matching mediatype : ffdshow Audio Decoder, DirectVobSub (auto-loading version), CoreAAC Audio Decoder, ACM Wrapper
375> Trying connection to ffdshow Audio Decoder :
375> OK, connected to (In)ffdshow Audio Decoder
375> # Rendering output pin C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv(Audio) -> ffdshow Audio Decoder(Out)
375> Filters matching mediatype : AC3Filter, ffdshow Audio Decoder, DirectVobSub (auto-loading version), Default DirectSound Device, Mpeg Splitter, CyberLink MP3/WAV Wrapper, FLV Splitter, MP4 Splitter, ACM Wrapper, MPEG4 Video Splitter, RealMedia Splitter
390> Trying connection to AC3Filter :
390> Failed connecting pin to AC3Filter, removing it now.
390> Trying connection to DirectVobSub (auto-loading version) :
390> Failed connecting pin to DirectVobSub (auto-loading version), removing it now.
390> Trying connection to Default DirectSound Device :
390> OK, connected to (Audio Input pin (rendered))Default DirectSound Device
390> Completed path : C:\Documents and Settings\Owner\Desktop\NHK ni Youkoso_(D-CTC 1280x720 WMV9 16x9 AAC TH).mkv(Audio) -> ffdshow Audio Decoder(Out) -> Default DirectSound Device
390> MyRenderFile finished : OK
Any idea what the problem is?
It lets me rip the wav.. but when i try to play the wav in all my media players it says a codec is missing heres the error message I get when I open it in WMP
Windows Media Player cannot play the file (or cannot play either the audio or video portion of the file) because the -0010-8000-00AA00389B71} codec is not installed on your computer
Any help would be greatly appreciated
have you tried using MKVtoolnix and mkvextractGUI to extract the audio stream?
Install MKVtoolnix, then install mkvextractGUI into the same directory and run MKVextractGUI.exe. The audio will still be AAC (it extracts the stream, no rip/conversion takes place), if you want to convert it, you could probably use a program like goldwave.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
AVCHD to MKV 5.1 Ripping
By amitabhbansal in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 04:33 -
DTS-MA ripping problems for MKV
By mattson in forum Blu-ray RippingReplies: 1Last Post: 21st Jul 2010, 16:56 -
MKV chapter ripping
By animalia in forum EditingReplies: 2Last Post: 5th Aug 2009, 21:53 -
Ripping a CD to wav files.
By efiste2 in forum AudioReplies: 6Last Post: 2nd Nov 2007, 18:31
