Hi, I'm having a slight issue with a project I'm working on.
I decided to splice a bunch of FMVs from the PSX game Fear Effect into a cohesive movie. However, I am also using some in game footage with it, and it seems to be at a lower sampling rate.
Using VirtualDub to put these avi files together always gives me an error telling me one sampling rate is lower than the others.
How can I fix this?
I can post the videos if needed.
BTW, my Avis are encoded with divx at the Home Theater profile
Thanks!
Closed Thread
i posted with the same problem in the noob section. From what i can figure the problem is specificly the video sample rate. One part of the video is 12 and another 16. Nero dosent like to burn this and virtual dub dosent like to join them.
VirtualDub will only join if everything is the same about the two (or more) videos - video must be the same frame size and frame rate, and audio must be the same frequency and sample rate. So if you must join, you're pretty much left with re-encoding all videos the exact same specs, or taking your chances with one of the (less reliable) AVI joiners out there. One I used to use ages ago was called Peck's Power Join, and IIRC it used to do a pretty fair job with most sources. You may be able to find it on google.
If in doubt, Google it.
one similiar topic is enough.
https://forum.videohelp.com/viewtopic.php?t=304724&highlight=
just reply to bump it.
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 23:18 -
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 09:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 18:07 -
Transcoding Video - Bitrate, Sampling Rate etc Limits?
By Leo48 in forum Newbie / General discussionsReplies: 18Last Post: 22nd May 2008, 09:38 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09
