I was looking for a conversion from vcd that I have to put those videos on a dvd. The cds are playable on a dvd player so I was wondering how to rip those cd files and convert them to dvd format.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
Simple enough. Extract out the AVSEQnn.DAT as a MPEG-1 file. Convert the audio from 44.1Khz to 48Khz, the DVD standard. Author and burn. You can also drop the MPEG-1 into TMPGEnc DVD Author and it will automatically convert the audio. MPEG-1 video meets the DVD standard, just the audio needs to be changed.
Other options: Look to the left in 'CONVERT' and pick VCD to DVD.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
