hi guys
i decide to buy a capture card that can get high quality clips and i usually cap spor clips and want to get best quality.
what do u guys think?is avidv card that capture in more bitrate than mpeg-2 give better output quality?
i will change the format to XviD 2mbps bitrate in both situation
i mean if i changed both of them with same adjusmet will the quality change or not
and i also can record in 2 mbps mpeg-2 format,if i buy a mpeg-2 hardware card
what do you suggest?i just want high quality?
let me explain
i mean i can cap with 30 mbps with Dvconventor and 15 mbps with mpeg-2 hardware.
after this i convert both to 2mbps XviD file.
is the quality be same or how it would be different?
i think some body should now about this
Hardware Mpeg-2 or Software ?
By video80 in forum Capturing and VCRReplies: 24Last Post: 7th Mar 2012, 21:25 -
Hardware MPEG 4 Encoders: Worthwhile?
By darkarn in forum Capturing and VCRReplies: 6Last Post: 29th Jul 2010, 20:16 -
Hardware MPEG-2 encoder cards
By cybertheque in forum Video ConversionReplies: 20Last Post: 20th Oct 2008, 20:51 -
What hardware do I need to go from VHS to Mpeg (or avi)?
By RichTJ99 in forum Newbie / General discussionsReplies: 8Last Post: 26th Oct 2007, 01:54 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 08:52
