How can I create a single cd or dvd with multiple Divx files and a menus?
Results 1 to 12 of 12
https://www.videohelp.com/tools?tool=DivXMediaBuilder
but it wont work on standalone dvd players...then you need to convert to dvd. -
Not enough information.
Do you want to keep them as Divx on the DVD or do you want to convert them to MPEG so the video will play on a regular DVD player? Divx menus are usually from the Divx player. Divx 6 can do custom menus, but the player has to be able to use that format.
If you are converting to MPEG, then just about any authoring program can do that. You encode the Divx files to DVD compliant video and audio and use the authoring program to create the menus. A simple way to do this with limited menus would be to use a program like ConvertXToDVD and drop all the Divx files in there. There is also a freeware version, DivxToDVD that is more limited.
And welcome to our forums.
My standalone dvd player plays Divx. I want to keep the format of the video Divx 6.2, have mutiple video clips on one disc and access them thru a menus.
Which DVD player do you have?
If cameras add ten pounds, why would people want to eat them? -
Just write them as data files to the CD or DVD and be happy with whatever menu system the player provides. Unless you have a DivX6 certified player, but they are scarce.Originally Posted by Popejohn
/Mats -
Pioneer dv-588a. When multiple files are on one disc the player doesn't provide a menu it will play each file one after the other with no way of selecting a specific file without fast forwarding through the disc.
Then I think your only option is to reencode the DivX movies to DVD specs mpg and author as DVD. Or, live with what the player provides in respect to AVI playback/(lack of) menu system.
/Mats -
I have a small portable DVD-player PDVD-LCD 3051 from Universum (home brand of german department chain Quelle). If you play a data DVD with DivX-movies then it also starts the first movie automatically, but if you push on stop then a player menu is displayed which allows you to select a specific movie.
Popejohn have you tried to find out if you push on stop on your player if such a menu is available? -
My Liteon 2002 has an option to automatically start playing files or to display a file list.
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 15:04 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 09:57 -
Divx Multiple Files To One
By mike202513x in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2009, 01:53 -
Opening Multiple files in Dr. Divx
By clawg in forum Video ConversionReplies: 0Last Post: 8th Apr 2008, 13:04
