Been using the latest version of Super to convert Real movies to .avi (in order to use on a portable PMP).
However, sound is out of sync with video.
I am new to conversion and the Super tool.
Any suggestions or ways to approach this?
Stan
I am out of sync on the computor.
Are there any guides out there?
Sorry about the post to Tools. Noticed forum after I posted.
ThanksStan -
Supposedly, according to the SUPER FAQ and posts on their forum, sync issues are usually caused by picking a frame rate different than the one used in the original video. As far as I can recall, SUPER doesn't pick the proper frame rate accordingly - it just uses whatever it was set to in the past - so you'll have to know the input movie's frame rate and pick the same rate for your output.
If cameras add ten pounds, why would people want to eat them? -
How can you determine a movie's frame rate?
Trial and error?
ThnksStan -
I'm not sure about RealMedia formats... RealPlayer doesn't seem to provide info about framerates. If you're able to play RM and RMVB files in something else, such as mplayer, or Media Player Classic, you should be able to get more information about the videos there (including their framerate).
I don't know if any of the tools in VH's Tools section are able to get framerate information from a RealMedia file, unfortunately.If cameras add ten pounds, why would people want to eat them? -
There is a real video shell extension (also availble as a standalone exe from recollection) written by I think Dark-Cracker (author of AutoRV10). It gives you the framerate, as an average though since rm files can be VFR. avi on the other hand must be CFR.
Lots of Trouble Converting FLV to AVI
By elykl335 in forum Video ConversionReplies: 5Last Post: 27th Feb 2012, 15:06 -
Trouble with Ripped DVDs/converting .VOB to .AVI
By research in forum Video ConversionReplies: 1Last Post: 15th Jul 2010, 15:42 -
Trouble converting avi to dvd
By illyad in forum Video ConversionReplies: 1Last Post: 18th Dec 2009, 08:34 -
Trouble converting OGM to AVI in AllToAVI
By m93 in forum Video ConversionReplies: 8Last Post: 21st Jul 2008, 18:21 -
trouble converting Quicktime mov. to avi (on windows XP)
By pifkel in forum Video ConversionReplies: 3Last Post: 31st Dec 2007, 04:19
