    Aug 2002
    Australia
    Nero Showtime V3.0.1.3 gives an error message saying the DTS Decoding Functionality is NOT available when playing DTS encoded files (note: it converts it to a PCM stream). I've contacted Nero Tech Support who just e-mail back a cryptic "This feature is currently not available".
    However the good news is it you re-installed the previous version (V3.0.0.1) those DTS files play no probs. I've now asked Tech Support what the story is and when/if DTS support will be back in the product and if it should be in the release notes.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    lic issue
    Aug 2002
    Australia
    FYI, I got the following from Nero Support "DTS was never supported by Nero ShowTime. It might be that you have had filters from a third party software installed which enabled you to play DTS sound. Unfortunetly we canīt give you any information about the future support of DTS in Nero. Iīm very sorry that I canīt help you more."
    The thing is, it just works with V3.0.0.1 (just uninstalled Nero the reinsalled the last version)and as you can see from the Screen Shot you even get the DTS logo in the player
