hello,
just a dumb newbie question:
I have Terminator in DIVX format, and I'm using
TMPGEnc to convert it to AVI to make a VCD.
The source file is about 450megs. The output
file is going over 1 gig! Is this correct...and
I'll need 2 (or more) cds to burn it on?
THANKS!
not is not used a better temple than the one you are useding
e-mail me if you want more info.... -
yes, more help please.
what template should i be using?
or should I use something other than TMPGEnc?
Newbie question about blu ray ripping and converting
By pete7769 in forum Blu-ray RippingReplies: 8Last Post: 12th Jan 2012, 17:02 -
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 16:56 -
very newbie question about converting video.
By br9541 in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 23:34 -
Newbie question, swf converting
By joppz in forum Video ConversionReplies: 3Last Post: 5th Nov 2008, 09:02 -
Complete newbie question: Converting everything to AVI
By mariognome in forum Newbie / General discussionsReplies: 9Last Post: 20th Jan 2008, 14:57
