I am using TMPGEnc to take a file recorded as XVCD 3.5Mbits, and convert it and clean it up into a properly formatted VCD.
Everything works fine and it creates a properly formatted VCD, but the file size is way to large (about the same size as the 3.5Mbs XVCD file was). When I play the new file, it plays correctly but the time of the new file is way too long and it stops on the last frame and just shows that frame for a long time.
How can I make the new file have the correct size after converting it from MPG 3.5Mbs to MPG-VCD 1.15Mbs?
Results 1 to 1 of 1
Extracted subtitle timing problem.
By Orange-kun in forum SubtitleReplies: 0Last Post: 2nd Mar 2011, 12:20 -
Problem with ProjectX - extraction of subtitles from TS with timing errors
By anthara in forum DVB / IPTVReplies: 1Last Post: 23rd Jan 2010, 08:26 -
mkv2vob subtitle timing problem
By HeroSmero in forum Video ConversionReplies: 1Last Post: 5th Jan 2010, 18:31 -
Problem downloading Stopzilla updates -- Server keeps timing out
By JudgeGarth in forum ComputerReplies: 3Last Post: 24th Apr 2009, 11:37 -
mpeg file subtitle timing problem
By ecc in forum SubtitleReplies: 5Last Post: 25th Jun 2007, 07:07
