I have almost 150 avi files (divx & xvid) and most have 25 fps frame rate. I need to get them all to 29.97 fps (NTSC), so I'm loking for a batch framerate converter tool. Does anyone know if that exists?
Why ? Doing a straight framerate conversion is likely to cause audio sync problems, and will also speed up the playback. You really need to re-encode these correctly, and even then you are likely to get jerkiness as a result.
Ask yourself why you need to do this, and if there is an alternative. If you are converting to DVD, you are better off converting to 23.976 with 2:3 pulldown, than butchering to 29.970.Read my blog here.
I'm using sub-clips of these to splice into 29.97fps video and I use Vegas to do that. In Vegas the 25fps is always out of sync and I have to correct that manually beforte I can continue my splice jobs. It eventually works but is very tedious. If I consistently convert them all to 29.97fps first, the splicing in Vegas will go much faster.
Looking for a batch stream converter...
By jamsponge in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2012, 17:29 -
Using MKVExtractGUI-2 batch tool
By CasanovaFly in forum Video ConversionReplies: 4Last Post: 2nd Jan 2011, 11:05 -
Scriptable tool to change AVI frame rate metadata?
By FurrTheBear in forum Video ConversionReplies: 4Last Post: 8th Jan 2010, 02:43 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
