I've noticed that the quality loss is acceptable with actual video, but when encoding cartoons it gets rather annoying to have about 20-30 pixels worth of fuzz/noise around all lines. Does anyone have any suggestions for the best way to avoid this?
-squeak
http://djsqueak.djcentral.com -
Apply a smoothing filter. Use TMPGEnc's "CG/Animation" quantize matrix (it can be patched into CCE, if you use that encoder). If using CCE, change the quality value to a low number (this causes it to focus on reducing edge noise). IMHO, TMPGEnc in general does a much better job with animation than CCE.
Assuming you use VirtualDub and want to use its filters to clean up a cartoon, here's a URL to help you out:
http://168.144.91.167/nickyguides/vdub-filters2.htm
Once you are there, search for the "HARD CORE NOISE REDUCTION" section (it's about 1/3 the way down).
Well, VHS capturing Mostly cartoons, having some questions:)
By zerowalker in forum Capturing and VCRReplies: 943Last Post: 30th May 2013, 23:30 -
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
Ripping Single Episodes of Cartoons for Re-Authoring - Jaggies
By jdmba in forum DVD RippingReplies: 7Last Post: 5th Aug 2009, 13:19 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Converting Cartoons to Xvid
By CartoonManic in forum Video ConversionReplies: 16Last Post: 15th Jun 2008, 16:31
