Basically I am trying to take recorded TV shows edit out the commericals so I have been using womble Video Wizard DVD to remove the commercials and to trim 5 pixels off of the top because for some reason (I think my DVR box) there is a white line that runs right across the top of my video. Nothing complex at all.
Everything is great except my once 4 GB DVD goes down to something like 1.8 GB. I thought this was kind of odd that the size would be that low. I know it will be cut down a bit becauise the comercials are removed but is that much normal? Im only editing out approx 20 min of the 60 min show... Is there some where in Video Wizard DVD to adjust the encodong? Ive looked every where but I may be missing it.
If not can someone suggest some other software I can use thats easy to trim 5 pixels off of the top and still get a quality encoder?
thanks
20 out of 60 minutes is 33%. And 1.8gb is close to 33% of 4.4gb It looks about right to me...
Rob -
But he's removing 20 out of 60 so he should be left with 66%.
Buy My Books -
If you are only playing your videos on your TV then the "white line" should be in the overscan region and you wouldn't see it anyway, hence no reason to crop.
If you crop then MVW is re-encoding every single frame, obviously at a lower bitrate than your capture since the size is being reduced. This is lowering the quality somewhat and taking much longer to process. You can adjust the bitrate when you export under the video tab."Art is making something out of nothing and selling it." - Frank Zappa -
By removing the white line you are also removing closed captioning that might exist.
Ive searched around and there are some many software packages out there but Is there any other software out there that can easily do the crop simialr to WVD?
Thanks for all your replies!
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
Womble video wizard mpeg dvd
By Remyisme in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2008, 14:47 -
By newshoes in forum Software PlayingReplies: 10Last Post: 20th Mar 2008, 10:22 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52
