Hi.
I have a pioneer 110D rewriter
It reads discs/files excellent, but when it comes to ripping to disc, the drive keeps crashing.
Is the drive broke or could it be something else ?
I have even tried using different types of media, still no look.
Thanks to all the reply.
I'm not so sure the drive is crashing, more likely the ripping program.
And what do you mean by 'ripping to disc'? 'Ripping' usually means decrypting and transferring the contents of a DVD to the hard drive of the computer. Are you doing on-the-fly copying? Or are you referring to the whole process of ripping, encoding or transcoding, authoring and finally burning?
What programs are you using? What are your steps? -
Hi.
Sorry i'm new to all this.
What i mean is, the rewriter reads contents of a disc, then i take
the disc out and put in blank media to copy contents the rewriter
will not copy, it just keeps crashing.
The same happens when i try and copy files from the hard drive.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 13:18 -
Laptop rebooting during burning with Pioneer DVD-RW DVRKD08RS rewriter
By rock_king_my in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Sep 2009, 05:04 -
ffmpeg keeps crashing when using DVD Flick
By djsuavetype in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2009, 14:06 -
LG GE20NU10 Super Multi Rewriter not showing up!!!!
By hassanthedon in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Oct 2008, 10:06 -
Samsung Writemaster DVD Rewriter & Ripping DVDs
By rock_king_my in forum DVD RippingReplies: 1Last Post: 7th Dec 2007, 01:47
