I bought 2 original dvd's and wanna make some security back up of them.
But in that back up I wanna change subtitle colors about one of that dvd's.
eg: DVD # 1 has yellow subtitles and DVD # 2 has white subtitles. I want to change the color subtitle from DVD # 2 to became the same as yellow one like DVD # 1.
How can I do that?
I try use PGCEdit, importing the colors from DVD # 1 to DVD # 2, in my HD. But the colors didn't change how I expect: the colors are different, despite I import exactly the same parameters from DVD #1 to DVD 2?
I really wanna know how to import / export such kind of subtitle colors between different dvd's, because in some authoring projects I really appreciate the original studio dvd color palletes ( concerning about subtitles ) and I want to reproduce them identical in my personal back ups and projects later.
Any clue and help about the subject are welcome.
Best regards.
I would try IfoEdit. Open VTS_01_1.IFO (or whichever file name the main movie has. Not VIDEO_TS.IFO!) from DVD#1. Double click on "VTS_PGCITI" to see the underlying structure, and select a PGC with the desired colours, for instance "VTS_PGC_1". Choose "Copy Colors from this PGC" from the Subtitle Color-menu.
Now open the PGC in DVD#2 that you want to modify, using the same method as above. Choose "Paste Colors into this PGC" from the Subtitle Color-menu and save the result. Since this will modify the IFO-files I suggest that you make a backup first. -
Use DVDSubEdit: https://www.videohelp.com/tools?tool=DVDSubEdit
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I'll do a test with Ifoedit and DVDSubedit too, ok?I would try IfoEdit. Open VTS_01_1.IFO (or whichever file name the main movie has. Not VIDEO_TS.IFO!) from DVD#1. Double click on "VTS_PGCITI" to see the underlying structure, and select a PGC with the desired colours, for instance "VTS_PGC_1". Choose "Copy Colors from this PGC" from the Subtitle Color-menu.
Can you tell me if it's possible to "clone" not only the palette colors from one dvd to another, but including their fonts ( size, etc )?
If not, there is some program that can copy/clone/discover which fonts dvd subtitles use?
Thanks again.
best regards -
GUI for dvdauthor:
How to change the color of converted subtitles with Txt2Vobsub
By uher in forum SubtitleReplies: 5Last Post: 27th Mar 2015, 11:00 -
Change from a color to another in a video
By Nokiamania in forum EditingReplies: 4Last Post: 7th Jul 2008, 02:51 -
Can a DVD recorder change a DVD color system?
By coody in forum DVD & Blu-ray RecordersReplies: 6Last Post: 14th Dec 2007, 13:16 -
ConvertXtoDVD - Can't change subtitles color
By Phil240 in forum Authoring (DVD)Replies: 5Last Post: 8th Dec 2007, 04:03 -
Subtitles : lower position / change color?
By izzat in forum SubtitleReplies: 2Last Post: 25th Aug 2007, 11:21
