Hello to everyone,
I want to make a game like SEGACD's road avenger ( for ones don't know that one then like
dragons lair ) I have nearly all figured out except on how to draw the status bar for the player,
I know 1 way to do it but is going to be hell long as i'm using 25 fps the idea is to draw it on each frame 1 by one with a paint program but sounds nuts to do it this way as later I might want to make it in to HD DVD or what ever in future so how can I do this with a video editor ?
I mean open the video and paste the statusbar in every frame at once ?
I need few status bars with 100% fuel then 95% then 90% untill 0% Fuel.
Hope someone understands me, I have a quicktime on pc and mac and imove but i never used,
also tmpgenc and virtualdub and some other editor may be.
Note: the final video output must be m2v.
I hope the solution is easy and the tools are free.
Oh and about audio does anyone know a website with free wavs ( with no problems related to royalties ) ?
AviSynth can do it. Check out the following commands/functions:
animate
overlay
stackvertical
pointResize
subtitle
I am thinking first off, you make a function with a blank (black) clip that has a framesize of 720x30. Then you resize it smaller while adding a white border to the right edge. Use the animate command to make it happen over several frames.
If you want to put a number on it, use the subtitle command.
Then you can paste it over the current video using overlay or a combination of crop and stackvertical.
Darryl -
Any other altenative to this?Originally Posted by dphirschler
I don't understand and i'm not in the mood of learning another cli program and another programming language -
I would say dphirschler's method is fairly easy, especially if you don't want to pay several hundred euros for a professional program. And please use a more descriptive title in the future for your posts.
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 21st Aug 2010, 23:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 18:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
