I read the following post on how to combine subtitle (*.srt) into a DVD
https://www.videohelp.com/forum/userguides/220351.php
I got the following install:-
1. DVD2SVCD
2. For encoder, I used version 2.524 (TMPG Encoder)
After running the program for a while, I got the following message in the log file:-
Executing SpuMux. Commandline:
"G:\Video Software\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 0 "G:\Subs\en1-1.xml" < "G:\MPlex_Muxed_File00.mpg" > "G:\MPlex_Muxed_File00-subbed.mpg"
SpuMux failed for unknown reasons!
For details open: "G:\Subs\SpuMux_log.txt"
When I open the G:\Subs\SpuMux_log.txt, I see the following:-
G:\Video Software\DVD2SVCD\DVDAuthor>"G:\Video Software\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 0 "G:\Subs\en1-1.xml" 0<"G:\MPlex_Muxed_File00.mpg" 1>"G:\MPlex_Muxed_File00-subbed.mpg"
The system cannot find the file specified.
Can anyone help me on why the files and not created?
The obvous stuff...
is en1-1.xml there?
is MPlex_Muxed_File00.mpg there?
What happens if you try to run that command-line manually? -
The directory G:\Subs is created and en1-1.xml is created but nothing is inside, coz the command is looking for the file:-
1. MPlex_Muxed_File00.mpg
2. MPlex_Muxed_File00-subbed.mpg
Looking at the command, it looks for the 2 files but I dun know when the 2 files are created.
How to add your own subtitle to DVD (keep menu, multi-pgc)
By bluedha in forum User guidesReplies: 339Last Post: 10th Oct 2013, 20:11 -
Resolved: Use Subtitle to Create Border on DVD Without Re-encoding
By sambat in forum SubtitleReplies: 6Last Post: 26th Feb 2012, 07:07 -
create/add subtitle
By akakiami in forum DVD RippingReplies: 1Last Post: 15th Aug 2008, 04:40 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
i add subtitle to a dvd and the coulor after reauthor is black!!!
By siopilos in forum SubtitleReplies: 1Last Post: 18th Jul 2007, 21:19
