  1. I'll try to make this short and clear hee hee.
    I have recorded a whole series of an old cartoon keeping the beginning song devided by the episodes. I would love to put them on DVD so that the authoring is as follows:
    1 Starts in MAIN MENU with the buttons to select one of 5 episodes;
    2 After selecting the episodes it runs the beginning song;
    3 After the beginning song runs the episode;
    4 After the episode it runs the ending song and goes back to MAIN MENU.
    My problem:
    I would like to put the videos of beginning song only once to save space, is there a way to authoring so that you tell the PC/DVD Player that after the selection of Main Menu, before going to the episode selected, it has always to play the Movie XYZ (in this case the beginning song video)?
    I use DVD lab Pro in case it helps you more.
    Thanx in advance.
    Apr 2004
    Miskatonic U
    Create everyhing as a seperate title, then use either end actions, or title playlists (it depends on what your software supports) to direct how to play. With end actions the intro music is more diificult, but the rest is easy.
    Read my blog here.
  3. Thanx alot. At first I couldn't figure out what you were talking about, but now yes. On DVD Lab, Menus are managed in 2 different ways: VTS menus and VMG menus. I was always using the first method as the easiest, but actually it is the VMG menus on the software that allows more option....like playlist
    Now making those kind of DVD is even much easier.
