Hello,
I encoded an .avi file by frameserving it using Virtualdub and CCE SP. I used Virtualdub to clean up the video a bit with some filters.
Anyway, the result is two elementary file: an MPV video file and a Wave audio file.
Is there a simple way to re-mux these two files into an MPEG-2 file, to be later played on a DVD?
Thanks!
Chris
P.S.
I had to encode into elementary streams because CCE SP would find errors and stop if I tried to encode as one MPEG file. But encoding elementary streams worked just fine.
if you are making dvd you can just use an dvd authoring tool supports elemantary streams like tmpgenc dvd author or dvd-lab or dvdauthorgui.
muxman worked perfectly for me in the same situation, and quickly created a burnable VIDEO_TS file.
I used the freeware standard version (v15P): http://www.mpucoder.com/Muxman/versions.html
3 movies, 6 elementary streams, 1 DVD
By Pholder in forum Authoring (DVD)Replies: 1Last Post: 5th Aug 2010, 08:51 -
Multiplexer for elementary streams for a BD-R / AVCHD
By BobaFett77 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Jun 2010, 16:59 -
demux a .mp4 to elementary streams
By halsboss in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 16:38 -
How do you join elementary streams?
By rayden54 in forum EditingReplies: 0Last Post: 5th Jan 2008, 20:43 -
From DVD VOBs to proper elementary streams
By gabier in forum Video ConversionReplies: 9Last Post: 28th Nov 2007, 21:48
