ok so when I convert avi/divx or whatever into vcd/svcd it goes all the way to 100% and then it go to some wierd time and says theres 05030465 or w/e but a really long time... I dont know what the deal is. I have a clue that it might be that the file is over 80mins long? But thats just a theory.
Any help would be fan-freakin-tastic! THANX!
Davey!
Ditch WinAVI and get a real encoder. Why ? Because it is unreliable, faulty and a rip off. Try contacting WinAVI support about your problem and see how far you get. You want to know why they are resposning to your problem, because they are too busy spamming our forums telling us just how good the program and their support is.
Try something like DVD2SVCDRead my blog here.
There are many tools available for conversion. Take a look in the Tools section and/or in the HOW TO - CONVERT section for guides on using the different tools.
Google is your Friend
I'm transferring about 100 VHS tapes - pixellation problems
By mw01908 in forum Capturing and VCRReplies: 32Last Post: 15th Sep 2011, 01:05 -
Starting over with WinAvi problems
By alex0000 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2010, 04:30 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:10 -
WinAVI Audio Problems
By thegun in forum Video ConversionReplies: 7Last Post: 23rd Aug 2007, 12:50
