  1. I have made many successful dvds with dvd-lab pro. This time I attempted including a ac3 audio with the menu (I dragged the ac3 file from assets to the menu). I compiled the dvd with no errors. When I go to look at the video_ts folder, I see no ifo or bup files, and about half of the .vob's are 0kb. I tried compiling it multiple times, but it always ends up the same. What should I do?
    The line below is true.
    The line above is false.
    Which line is true and which is false?
    Apr 2004
    Miskatonic U
    Which version of DLP ? Older versions were prone to this type of problem on occassion.
    Also try scannning the AC3 file with AC3Fix, just to be sure it's clean.
    Read my blog here.
  3. Compiler version 3.0.0.170
    Pro 1.60 BUILD 060101
    the ac3 was clean
