Is it possible to make a 4:3 menu linking to chapters in a 16:9 widescreen movie in dvd lab pro? Or would i have to link up this after compiling using ifo edit?
You can have a 4:3 menu and a 16:9 movie in DLP. Configure this in the Project Settings dialogue. You can't have a mixture of 16:9 and 4:3 menus, so all menus would be 4:3. You can also control how the menus appear depending on how the player is configured.
Read my blog here.
I've been working with this as well, but my solution has not been that simple.
...because I use a motion menu that is 4:3 "letterboxed", I needed to modify the menu setting in IFOedit to be "16:9, auto pan and scan". I have a 4:3 TV and it looks like the original DVD I ripped it from. I assume that for a widescreen TV it would look larger yet appropriately fine in terms of ratio.
Here's the problem I'm having: the chapter buttons I created for the menu look ok when viewed on my 4:3 TV; when I change the DVD setting to be 16:9 so I can make sure the buttons would display correctly on a widescreen TV --and when I play the DVD on my PC -- the chapter buttons are skewed and not adjusting to the new display ratio. However when I look at the commercial DVD I ripped the menu from, the chapter buttons always stay in the correct location regardless of the DVD setting being 4:3 or 16:9
Would anyone have any idea why this is happening, and how to correct? I have tried everything, it's driving me nuts. Thanks. -
The 'scaling' of 16:9 videos is done by the player (widescreen/letterboxed/Pan&Scan), but not the scalling of subtitles (button highlights are just a special kind of a subtitle). Therefore if all options should be available (widescreen + letterboxed + Pan&Scan) you need 3 'sets' of subtitles for the buttons. I don't know if this is possible/supported by dvdlab.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks...I'll have to keep plugging away...just wondered if anyone who used DVDLAB-PRO came across this problem.
Need some Menu help from a DVD-lab PRO master
By jeanpave in forum Authoring (DVD)Replies: 13Last Post: 4th May 2010, 16:03 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 18:27 -
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 03:38
