Hello,
We purchased KOSS DVD player KS 4110. Recently when I tried playing DVD in the player, the pictures appeared in black and white. I tried playing other dvds there was no color in the pictures. I ensured the disc format was not according to TV -set used (PAL/NTSC).
What could be the reason for the loss of synchronization in color?
I would appreciate suggestions.
Many thanks,
a4chan
Plugging the s-video into a composite connection will also produce black and white images. Check your leads and connections. PAL playback on NTSC only kit will produce black and white, but it usually also causes picture rolling as well. If your picture is stable, it is probably connections.
Read my blog here.
Thanks a bunch for the response! I will check the connections again. Yesterday i tried switching between PAL/ NTSC, the picture started rolling fast. How do I stop the picture from rolling??
Thank you verymuch!
A4chan -
I was able to fix the rolling pic by switching back to NTSC and will try to chk the connection again....
Thanks,
A4chan
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
Is It Possible To Create A Custom Color From A Picture, For Text In Paint?
By V Bot in forum ComputerReplies: 10Last Post: 1st May 2011, 23:00 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 17:41 -
tuning picture cleaning off color tubes?
By BroomQueen in forum DVB / IPTVReplies: 8Last Post: 8th Dec 2008, 09:01 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00
