All my movies were .avi file types but i converted 1 movie and now all my other movies are saying they are video files??? does that mean i do not have to convert them or do they still need to be converted.... i am not sure whether to think they auto converted themselves
convert to what with what tool?
where does it say video? what is the file extension?
they aren't auto converted... -
Yes, that's probably just Windows sticking a generic icon on them. Do you have 'Hide extensions for known filetypes' unchecked? Then you would see the true extension name. In any folder: Tools>Folder options>Views>then go down the list a little and uncheck it.
That was exactly what it was i had the hide file extensions checked and when i changed it... it showed the true extension which was avi on most but the ones i converted thanks
You probably want to have a tick next to show hidden files and folders also. It helps your AVS find virus and trojans if it can see all the files and their extensions.
File type question
By Videographer in forum Newbie / General discussionsReplies: 0Last Post: 27th Jun 2011, 10:20 -
question about vhs to dvd conversion file type
By lotrmorgoth in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2009, 10:33 -
videroa question--file output type
By Dr.Gee in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 18:17 -
question about settings and best file type on cheap TV card
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 29th Nov 2007, 02:09 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
