Hello there,
I've got a big problem here. Im doing a dvd-presentation with some cars videos for my boss which must be finnished by today. I had to take the videos from a dvd and did that using DGIndex. Afterwards i had to cut some parts because the guys managed to put a 4:3 and a 16:9 video source into one 4:3 video - which looks pretty crap as you might think.
So what i have now is 2 parts of the video: one 4:3 and one which i need to recode to 16:9. The 2 files where cut from the DGIndex File and are m2v-files now.
I tried re-encoding the 2nd file using TMPGEnc 2.x to 16:9 which works fine until the encoding process reaches 91%. The encoding keeps running to the end, but the picture freezes at 91%. And in the Video its frozen from that point on.
What am i doing wrong? I tried several times and used different versions of TMPGEnc. Any Ideas? Thank you!!!
Guest34343Guest
Does the M2V play properly before reencoding?
Or it this issue now dead because it's past your stated deadline?
ripbot264/meGui : h.264 stops encoding...
By mshilly in forum Blu-ray RippingReplies: 8Last Post: 28th Dec 2012, 04:25 -
Megui encoding stops
By sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 21:36 -
BD Rebuilder stops encoding
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jun 2011, 10:01 -
AVStoDVD stops working after encoding video
By tperkins13 in forum Authoring (DVD)Replies: 1Last Post: 19th Apr 2011, 07:10 -
AlltoAvi Stops Encoding Prematurely
By Startropic1 in forum Video ConversionReplies: 3Last Post: 6th Jun 2009, 19:49
