  1. i use video galaxy package to rip shrek and encode
    step one rip files with dvd decrypter (i apply no settings)
    step 2 av12vcd(i apply no settings)
    step 3 encode with tmpeg
    i load video cd (pal).mcf template then goto advanced and changed source aspect ratio to 16:9 625 pal
    video source is interlaced & video range is full screen maintain aspect ratio
    are these setting correct if so why is the sound volume so low and how can i boost it
    Jun 2001
    ZiM City, MN
    In Tmpeg on the advanced tab and click on "Audio effect" There you can increase the volume. I have mine set at 400% and that works fine for me.
