Im using vegas 6 and trying to capture video from the sony dcr-dvd403 but for some reason when i plug in the usb to the cam it just comes up as a cd player and vegas 6 wont see it at all!!!!!! am i doing something wrong???? why the hell a sony software is not seeing its own camera?!??!?!?!?!??!?!
Results 1 to 11 of 11
Is it a dv camera? You need to use a firewire port for the best transfer. Some won't see usb at all. Though some do.
EDIT - Is it a direct dvd recorder? Does it record straight to a dvd? Then you can use dvd decrypter or dvd shrink to copy the dvd disc files to the pc and open the video_ts folder in your editing program.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
sony 6d will import that crap format --
you have to use camcorder import setting as in your manual and instructions and the help file and the sheet that came with the software in the box ...and also instructed on the sony web site and forums and sony support .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i no but before i do that i have to finalize the disk meaning it cant be used again and i neeed to keep using those diskOriginally Posted by yoda313
ok i tried and updated to version d but it still wont capture the video.... and you can just register for their forums the old fashion way so thats not gonna work.... can anyone help me with this?????
Originally Posted by mol3000
what do you mean ? other than having to provide proof of purchase - you can register right away ...
did you read the sheet that came with the software in the box ? it explains a lot of how to use dvd created by those stupid camcorders ... though in many cases it is sill a pain ... really - those camcorders are just not really meant to be edited .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You need to keep using the discs?Originally Posted by mol3000
If you are adding additional video to a "not yet full" -R disc...then that is a shame. I'm afraid you need to wait until the disc is full in order to do any computer work on the DVD.
But if you are talking about an RW disc....finalizing doesn't mean squat on an RW. They can always be erased on a computer no matter what they are finalized on. -
Originally Posted by hech54
yes im talking about a -rw... i thought i read that on either one it couldnt be written to again??!?!?!?
PS: this isnt my cam... its my friend.... if it was up to me i would of bought minidv -
RW means Rewritable - Finalized or not!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Rewritable just means you can erase the disk and reuse it, doesn't mean you can add to it.
Sutable capture card and software to stream live TV to a Sony Bravia intern
By Fozzie_Bear in forum Video Streaming DownloadingReplies: 1Last Post: 29th Nov 2011, 23:49 -
Sony Video Hi-8 Editing Disk Lost. Need Free Capture/Edit Software
By Classic '57 in forum Newbie / General discussionsReplies: 13Last Post: 14th Jun 2010, 23:08 -
Have windows 7 and am tring to get video off sony cam but doesnt work.
By intheory in forum Newbie / General discussionsReplies: 4Last Post: 16th Mar 2010, 19:17 -
how to use Sony SR12 as web cam. HELP!
By pftjim in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 10th Jan 2010, 04:15 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
