  1. Member nbarzgar's Avatar
    Sep 2004
    Austria
    Hello,
    great tool, fast and easy to use.
    Is there a way to set the audio bitrate the audio will be converted to?
    I've got the latest version (Build 2.1.2308) and the audio is converted to (48 kHz) 448 kbps, the bitrate being far too high compared to source (VCD) and space taken on final DVD. I would like to set it to 224 or 256 kbps.
    Thanks.
  2. If I remember correctly (I'm at work without program access), you could process the audio outside of S2D (use VirtualDub or something similar, depending on your source type) and set S2D to leave the audio alone.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  3. Member nbarzgar's Avatar
    Sep 2004
    Austria
    Thanks for the advice, I would do that of course;
    I just thought it would be easier and faster to convert (S)VCDs, if that could be set (as - changeable - default for example) inside SVCD2DVD.
    That's what it is meant for, I think...fast and easy conversion.
