I use titantv.com and I love it for programing my fusion hdtv.
It does a great job of naming the show for me.
HOWEVER I was wondering if there is a service that will not only put the show name but the episode title as well? Is there any one out there that does that? Preferably free??
Results 1 to 9 of 9
tv.yahoo.com has that information.
But not sure if that's what your asking for.Want my help? Ask here! (not via PM!)
Thanks but I think just shows it passively.
What I'd like is one that would automatically name the show with that shows episode name.
For example:
When I record Deep Space Nine titantv will program my fusion for me and it will name the mpg file DEEP SPACE NINE. But it doesn't include the episode name. So when I do a week of recording it will be DS9, DS9(1), DS9(2), etc....
I guess its asking for too much but it would be a great extra feature to an already cool feature of titantv. If anyone knows of a service that does that I'd be interested.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I know you're not asking for this, but its an alternative, really.
What you can do as a temporary means is just D/L the complete listing
of all the Series and be sure that they are all listed in Season and
Episode order.
Then, numericalize them, so that they are easy to find, based on episode
currently airing.
(you're right, you are asking for too much.. but then, so do I)
-vhelp 4032 -
Thanks vhelp. That's probably the best I can hope for.
But I can dream can't I???
(being a couch potato is so hard you know
BUMP
Well the best I could come up with is to simply look up the episode and rename the file the same day I record it.
Its a slow manual process but its the only way I can see to do it. But it works well. Unfortunately TITANTV only keeps the current days listings from midnight to present and then forward.
Fortunately YAHOO's tv guide goes back at least two days fyi.
Well, you could go to tvguide.com and first D/L the listing (they have one)
of all the episodes in chron order. Keep 'em on your hdd somewhere's.
This is what I've done, so far. So, that'll be your start, too.
Wait till you get a dvd recorder with a HDD in it. Then, it'll *really* beIts a slow manual process but its the only way I can see to do it. But it works well. Unfortunately TITANTV only keeps the current days listings from midnight to present and then forward.
slow, cause you'll be recoring *everything*. And, the process is quite slow
for each hdd->rw project. For my setup, it's approx 30 minutes for 1hr tv
program recording. That's w/out editing out any commercials.
Regarding editing out commercial..
So far, in my short experience with a hdd unit, the best use for this process
is for when you are running out of hdd space, and you need to scabage up some
space to record something (which is always important to you) in a hurry.
On my rig, the process for freeing up space (for when you don't have the time
to hdd->rw->pc ten to twenty to fifty or more videos on hdd) is something like
this:
A - review video(s) recorded listing
B - select *each* video to cut commercials out and free space
C - using SPLIT function
D - delete those new (commercial) pieces
Funny how having a hdd changes all everything
Some crazy ideas..
Right now, I'm imagining various ideas of rigging up my unit to accept a
special-made ribbon cable that run's through my unit's hdd and to some kind
of switch box that i'll invent maybe, and connect them somehow to my mobo,
and when I want to pop out a hdd, all I have to do is switch something around.
Then, dvd2avi whatever (no more smartripper) VOB's on hdd and encode away
But right now, they're just crazy thoughts..
-vhelp 4041 -
Actually vhelp they have something like that I think for doing a hot format of xbox harddrives. You have to have the pc open and on and attach the harddrive to the computer. Then you do a live format of some kind.
That would probably be something similar to your idea. Just find a way to hack the harddrive and do a download to the pc. Shouldn't be too teribly hard - of course no more warranty
BUMP!
Well I finally got around to trying what I should have done in the first place. My fusion software allows me to manually type the name of the show I'm recording. So I've been laying out my recording schedule and manually typing the name of the show and the episode name. It works great
Unfortuanately when I use the automatic programing with titantv I can't edit the title name.
So what I've done instead is use titantv to get the episode name and manually enter in the time and date of the show. Then I type in the full name of the show with the episode name.
It's more cumbersome then the auto program titantv allows but I can name each file with the episode name. Now I can go straight to dvd authoring after I capture the file. I don't have to go check which show it was and then rename the file. Sure that only takes a minute or so but this way by manually doing it first I don't have to do it after I record it. Makes it much quicker on the post side of things
Is there a consolidated Stargate SG1 episode guide in print?
By yoda313 in forum Off topicReplies: 5Last Post: 2nd Aug 2009, 20:08 -
Web-based transcript-video w/hyperlinks???
By cannonbrown in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2009, 15:00 -
Web based player for playing large files?
By Joe_Dean in forum Video Streaming DownloadingReplies: 2Last Post: 6th Jan 2009, 21:25 -
Video Streaming Service, web based (beta testing)
By mitiania in forum Video Streaming DownloadingReplies: 0Last Post: 27th Aug 2008, 12:49 -
Complete Automation.... web-based interface?
By ab500 in forum DVD RippingReplies: 1Last Post: 17th Aug 2008, 13:46
